Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Jan 2016
    Unable to Load Guide
    Changed nothing from last night when everything was working -- guide in colour and inline .
    This morning I get 'Unable to load guide ' - guide is blank and no info
    Any ideas?? (kodi 16, cache ticked, 12 hours) ...
    Blackbear Blackbear199's Avatar
    gimme a bit.i know whats wrong but dont know why.shud be up in less than 1/2 hr.will post back.
    psycon changed the script and i dont know why but it disabled the way to download the files via the epg url way(i assume the nfps version also as it uses same links).
    looks like the only thing that will work is using the epg service or whatever he calls it.i dont use it so dont know.
    you will have to wait for him to answer.
    Jan 2016
    Quote Originally Posted by Blackbear199 View Post
    Thanks for the help - didn't get a guide using the latest epg updater .... still blank and no info
    Fresh install . useing built in pvr stalker. everything is working except getting unable to load guide error. any help would be appreciated. Thank you
    Jan 2016
    Quote Originally Posted by edmackay View Post
    Tried allsorts today to fix but I still get 'unable to load guide' error .... given up on it now as I changed nothing from yesterday .... bizarre
    Jan 2016
    Any update on this ?? a different box with a different build also gave the unable to load guide error ????
    Anyone ?????
    Jan 2016
    Tried the following ... wiped database files, pvr file in addon data ... still the same - unable to load guide error
    Installed the new epg updater after wiping my build and renetering details - unable to load guide error
    Tried the above on a different device - same unable to load guide error
    Any official word ??? Nothing was changed since Friday when all was working then all this ????
    psycon mentioned a updated version here,have you tried that.
    if its not workin then i have no idea,i had nothin to do with the epg updater method,only he can answer questions about that.
    http://iptvtalk.net/showthread.php?1...r-plugin/page7
    Jan 2016
    yep got latest updater installed .... xmltv gives unable to load error... does this on a different device that has a diff build so cant be my end ... ive even wiped my build .... provider gives grey guide but loads of info missing and all out an hour ... no messing or changing puts it inline so either way its broke for me
  1. Pvr stalker nfps unable to load guide
    By lopezn3 in forum EPG
    Last Post: 10-17-2016, 02:10 PM
  2. unable to load guide
    By arseniogomez in forum PVR Clients
    Last Post: 05-15-2016, 07:56 PM
  3. Unable to load guide after new install
    By abzlad in forum EPG (epg.ninja)
    Last Post: 05-03-2016, 09:36 PM
  4. Unable to load epg Guide
    By ramz in forum IPTV Private Server (NFPS)
    Last Post: 04-11-2016, 02:31 PM
  5. stalker nfps unable to load guide
    By danlevin in forum IPTV Private Server (Rocket)
    Last Post: 02-20-2016, 08:07 PM
