it showings channels and descriptions but the current times are not there..
anybody have same issue?
I'm on NFPS, but the EPG is down entirely.
Apparently working for others. I understand that it's not the same servers\service, just want you to know you're not alone scratching your head. Hope other iks66 members can chime in.
Same here on iks66 and no guide at all...just channels and logos.
I'm having the same problem my you guys will not load up
guys,just add the ********** repoafter that goto addons/install from repository,select ********** add-ons then services then stalker epg updaterCode:http://**********/clairvoyance
then in pvr.stalker select local file rather than remote url,then navigate to you usedata/addon_data/pvr.stalker folder and select the epg_xmltv.xml file
the epg updater will autommatically update the file every 24 hrs.
if you dont know how to add a repository then gotodownload the repository.**********.zipCode:http://**********/clairvoyance/
goto addons/install from zip file and select the zip file,then follow the instructions above from
--->after that goto addons/install from repository,select ********** add-ons then services then stalker epg updater
