if you are willing to wait till the sept 25 for shipping check out the AVOV VIXO Fuse
Two of the greatest qualities
to have in live are:
PATIENCE
and
WISDOM
avov better box but mag has better suport I have one avov that is stuck with package installer useless with mag if I have problem just do software update again and I am in busines
I have the mag254 and i was thinking about getting an avov. Does the avov have the portal setting like the mag254? I want to run the portal and Kodi on the same box (avov). Thanks
I´m new to IPTV, used to have FTA years ago.
I was about to buy a MAG254, but out of the sudden came across with AVOV, and it does seem to have better hardware than the MAG.}
I also can note that there´s tons of suppliers that work with MAG, which is not the case with AVOV.
All in all, I´d like to know your opinion on wether to buy an AVOV tvonline+ or MAG254?
I also was told that besides IKS service and VOD, there are tens of thousands movie titles available for free in AVOV. Is this true?
Is it easy to configure it?
Can you recommend IKS provider, that has great reliability, support, and huge content?
Thanks and best regards
yea get a avov plus and run kodi too click the banner to order one
how can I install portal on AVOV Tv Online V2 like on mag250?
not same talking water to oil
it is much easier to set a avov than a mag,it has more options and applications that can be nice if servers are down,like kodi as an example.
