Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
  1. #31
    Quote Originally Posted by Apathy View Post
    I got it had to add 12 digit number for token as well used
    RANDOM
    reset mac
    12 digit token -same number
    13 digit serial -same number + 1 extra random #
    12 digit device id's(both) -same number
    12 digit signature -same number
    confirmed working without the epg. thanks
    kodi 15.2 pvr stalker 0.8.3
  2. #32
    Mar 2016
    I am using IKS 66 router key. I have firestick and I am continuously getting ITV autorization failed. Please help
  3. #33
    pot?
    Apr 2015
    Quote Originally Posted by supr View Post
    Start here in the fire section:
    http://iptvtalk.net/forumdisplay.php?66-Amazon-Fire-TV
  4. #34
    Mar 2016
    I'm really lost here. I had Stalker Client NFPS working till the outage. It's no longer working after trying resets. I am using IPTV on Kodi 16 on my computer. I tried the new IPTV Stalker Papio but im getting device mismatch. Where do I find my serial number and such? I just have this installed on my laptop.
  5. #35
    Quote Originally Posted by castor9mm View Post
    First, Stalker Client NFPS will only work for Rocket and IPTV66, and will be sunsetted ... no longer updated and supported. psycon just rolled out his changes to the ********** updater that will configure the built in Stalker Client.
    Second, please read the release instructions for the IPTV Stalker Papiao (10.0.1). The Serial number and Device ID are made up by you, or you can let the add on do it for you by leaving 'Custom Info' off, but after you put them into the configuration, you will need to do an IPTV Reset to clear the device info mismatch.
  6. #36
    Mar 2016
    Thanks for your help dara. I got it working with the IPTV Stalker Papio 10. Does this mean I cant have a guide anymore? It's just a list of channels. Should I buy Rocket or IPTV66 instead?
  7. #37
    No, you don't need to buy Rocket or 66, you should try to get the built-in PVR Stalker working. You can also use an external EPG addon like iVue with IPTV Stalker Papiao as well.
  8. #38
    Jun 2016
    made it work. Thanks. Dara
  1. Device id mismatch
    By 3mike33 in forum PVR Clients
    Last Post: 03-01-2016, 01:49 AM
  2. Device id mismatch
    By 3mike33 in forum Introduce Yourself
    Last Post: 02-28-2016, 04:47 PM
  3. device id mismatch
    By JoeSshmoe in forum Kodi Discussion
    Last Post: 02-20-2016, 07:26 AM
  4. Device conflict device ID mismatch ?
    By Chrisss in forum IPTV Private Server (IPTV66)
    Last Post: 02-13-2016, 09:17 PM
  5. Device id mismatch
    By sxmdim in forum IPTV Private Server (NFPS)
    Last Post: 02-07-2016, 05:02 PM
