This post is from NFPS at fta just didn't see it here and still not working for others )
HI.
If you are getting this error in your KODI, it means that your addon is not sending the Device ID properly. Please follow these steps to fix it:
1- Go to this website
Online SHA-256 hash generator.
http://www.xorbin.com/tools/sha256-hash-calculator
2- Now lets generate a unique key that you will use as the device ID, You must create it using your MAC, Serial Number and Donation Number in the "Data" field with the following format:
00:1A:79:00:00:00-111111J111111-123456789012 (Enter it just like this)
MAC Address - Serial Number - Donation Number
3- Once you have entered the information into the data field make click on "Calculate SHA256 Hash" and you will get a key like this:
93822bec02caa9cf8981dd487ab0ac 739144e52ab5d62375a7 a98498cb9351b1
4- Copy this key and paste it into your addon settings in the device id section.
5- Do an IPTV Reset to your donation number using the following forms:
https://papiao.is/main/search_nfps/
or
6 - Reload KODI and try again.
NOTE: If you use our customized PVR Stalker Addon, it already generates all this automatically so you may only need to do the IPTV Reset part.
It really works!!!
See pics
http://i.imgur.com/ART44GV.jpg
http://i.imgur.com/dj3cItI.jpg
Still no guide but this is progress!
