Results 11 to 20 of 38
    Great news but just got home to try this and now the https://papiao.is portasl to reset MACS keep erroring out:
    This webpage is not available
    ERR_CONNECTION_TIMED_OUT
    https://papiao.is/main/search_nfps
    Feb 2016
    This is getting so frustrtaing - can someone please make a new guide on what we need to do with stalker starting from step 1
    I have been in and around and through so many threads and nothing is working - feels like im chasing my tail
    Using KODI
    Guys, both primary sites are down...
    http://www.iptvrocket.tv/
    http://www.iptvprivateserver.tv/
    Feb 2016
    Not to sound dumb or anything, but do i put this code im device id 1 and leave device id 2 blank?
    Im reffering to the hash code that gets generated by mac + serial + donation... I didnt quite understand if it should be put in device id 1 or device id 2 or both?
    Blackbear Blackbear199's Avatar
    enigma.although its a nice idea it so untru.
    any device id will work...no need for the crap....why?
    do this..
    reset mac
    13 digit serial
    12 digit device id's(both)
    12 digit signature
    i bet works
    the above wud be great if nfps had a database of mac's and serial numbers(which it dont) to compare the hash thats generated to a database which it dont have.
    Jan 2016
    yes I do
    Yes I'm waiting to pull the trigger on Stalker but waiting for clear and working steps to start to even try.
    This would be for new users only.
    Quote Originally Posted by smittyj77 View Post
    Using KODI
    Feb 2016
    [QUOTE=Blackbear199;107255]enigma.although its a nice idea it so untru.
    do this..
    reset mac
    13 digit serial
    12 digit signature
    i bet works
    the above wud be great if nfps had a database of mac's and serial numbers(which it dont) to compare the hash thats generated to a database which it dont have.[/QUOTE
    Ah ok, ill try that. Because im getting device mismatch error at the moment. I cant reset iptv though because nfps link mac adress link is down...
    if you cant reset your mac you are sol.
    Feb 2016
    Quote Originally Posted by Blackbear199 View Post
    So to clarify ur saying i should change my mac on donation page?
    Quote Originally Posted by Enigma2win View Post
    not change...reset.
    if you were using kodi and bought a mag then you need to change your mac as a mag mac is hardware coded
    ur using kodi so just reset ur mac and use the same one ur using or register a totally new one.
  1. Device id mismatch
    By 3mike33 in forum PVR Clients
    Last Post: 03-01-2016, 01:49 AM
  2. Device id mismatch
    By 3mike33 in forum Introduce Yourself
    Last Post: 02-28-2016, 04:47 PM
  3. device id mismatch
    By JoeSshmoe in forum Kodi Discussion
    Last Post: 02-20-2016, 07:26 AM
  4. Device conflict device ID mismatch ?
    By Chrisss in forum IPTV Private Server (IPTV66)
    Last Post: 02-13-2016, 09:17 PM
  5. Device id mismatch
    By sxmdim in forum IPTV Private Server (NFPS)
    Last Post: 02-07-2016, 05:02 PM
