Same here. Loads on the bar 25% then stops
yep, progressed from 'error' to a 25% stuck yellow bar. frustrating!!!
I try everything... and keeps the authentication problem in the TV...the video club works great, I messed with the media player and nothing, reset, device id...so i think is the server...I try other server and work fine but i preferred this one, the guide work great just when I click to se the channels authentication crap failed,,..
its same for most people guide there but channels don't load
free bloomberg channels are working. 202 203
For the life of Me, I can't find this setting your talking about (even in the new STB Emulator that has just been released), any way u can take a photo where the setting is...
settings is on the right corner of your tv screen, but it is hidden. if you have a usb mouse or if you remote has mouse option you can move mouse to the top and click once.
you will see a slide bar with three dots at the end.
Three dots is menu where you will see settings.
Anyone got this. Fixed yet?
Now "Contact your provider to register this device".
Totally down
Again with problems.....im checking a box to see if it is fix....blocked....check my mac to reset or change it and there we go again :A PHP Error was encountered
Severity: Warning
Message: mysql_connect(): Access denied for user 'updater'@'10.1.1.102' (using password: YES)
Filename: models/donation_model.php
Line Number: 2139
What is this now????? and when i check my route in the server it change...if i dont change it, why this happen..
