I cant get in either, i think its on their end
Hopefully so i cannot figure out what else to do. All my info is in correctly fresh mac retarted kodi several times but with same result i had my info in almost a month now preparing for this change i thought i would have a smooth transition didnt expect to have this much trouble
I have had issues on and off with the PVR client. Sometimes when I launch Kodi the Client will fail. It seems to be a timing issue because if I do the Settings - TV - Disable and re-enabling it usually starts fine.
I am trying to setup the PVR client on kodi / android. I failed until now to get it working, each time I enable the client and go to settings > TV and then enabled. It pops up a message no pvr clients enabled and send you to the screen pvr clients with all showing disabled.
Anyone has ever encountered this issue may be?
Go to Kodi system settings/add ons/my add ons/pvr clients/stalker client/... select configure, enter all your donation(id/password)/MAC/server Address/Guide Address, and save. (plenty of instructions in the threads for configuring stalker properly so wont repeat here,).
Go back to system settings/tv/General tab - Clear Data & confirm with OK. Go up to Enable, highlight, and PVR.Stalker Client will attempt to connect to server./kens
I did all that! stalker client v.1.0.3, Still nothing. Clear data, reboot. new mac etc. still authentication failed... very frustrated with the new authentication schemes. the server to change mac address itself is super slow. should i go back to v0.8.4 client?
I am having the same issue. First of all I cannot change mac address, if I enter all info as per instructed, I get message "can`t load Dll.
Quick question is the server address the same one we have always used? I'm trying to set up my NPFS yearly. Also what goes in the guide address?
