Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 126
    Jul 2015
    Lightbulb
    OK, I have found the source of the problem after some meticulous examination
    There is a typo in the URL given in the guide above.
    The URL should be https://papiao.tv/ and not https://papaio.tv/main/EPG......
    Please update the original post to prevent further confusion by members.
    Thanks!
    In the hills
    oops. done
    Jan 2016
    eh guys new at this have my mac addy and that is this set up for that i have android m5
    Jan 2016
    Has anyone been able to get the NFPS stalker client to work at all? Is anyone else having issues with switching channels within the pre installed client?
    Jan 2016
    No. That's not the issue. I caught the type o right away. Makes no difference.
    Quote Originally Posted by MasonStorm45 View Post
    I haven't had any issue with the preinstalled client, other than no color in the guide (extremely minor issue). You do need to set up the serial number, device ids and signature. Follow the instructions explicitly.
    Jan 2016
    Yea no issues getting it to work Just no color in the guide and not able to switch channels in the EPG. I can switch using the channel list though.
    To switch channels in the guide, you click switch when you get the description, or you can set up the default selection action in the TV settings>Guide to "Switch to channel"
    Feb 2016
    i am unable to load guide and fail to get stream url
    Jan 2016
    Yes I'm aware of how it works when you open the description. When I open the EPG and click on the channel. The program window isn't opening to give me the option to switch the channel
  1. Replies: 0
    Last Post: 03-06-2016, 10:52 AM
  2. Replies: 11
    Last Post: 02-28-2016, 12:40 AM
  3. Replies: 6
    Last Post: 02-10-2016, 06:06 PM
  4. Replies: 2
    Last Post: 12-16-2015, 11:55 PM
  5. Replies: 4
    Last Post: 10-21-2015, 09:23 PM
