you have to use the epg updater addon
@Hustler: I don't wish to use the EPG Ninja Updater addon.
The updater is a small addon that downloads the epg xml file to your device at a specified time. It isn't resource heavy and it works without issues for me. I wouldn't be reluctant to give it a try.
Quick question as I cannot find the answer anywhere, how do you tell the addon to pull 24 hours and not 72??
Note: The 24 hour pull does not show details and is for devices with lower ram.. the 72 hour has the show details.
Running 150mb cable broadband & mag254 :cool:
Thanks for the replies Psycon, Ilon and Dara. Yep, I tried to avoid installing any excess addons on my device but as its a small addon and reduces the load speeds for EPG, I'll give it a go.
Cheers
