Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
  1. #21
    Yes I did all that still one hour behind
  2. #22
    Jul 2015
    Receiving this error when trying to change mac on the papiao.is site. Is there an issue?
    A PHP Error was encountered
    Severity: Warning
    Message: mysql_connect(): Access denied for user 'updater'@'10.1.1.102' (using password: YES)
    Filename: models/donation_model.php
    Line Number: 1846
  3. #23
    notmember ljhookem14's Avatar
    Jan 2016
    Should I update from ScNFPS 1.0.1 to 1.0.3?
    psycon, I have been using 1.0.1 StalkerClientNFPS but should I update to the 1.0.3?
  4. #24
    Feb 2016
    When I try to uninstall Stalker Client NFPS 0.8.4 and install 1.0.3 (running Isengard on a MINIX android box, I believe I want pvr.stalker.nfps-android-arm-i.zip?), it appears to install fine, but when I check, it shows up as version 0.8.4 again - any ideas how to fix this?
  5. #25
    I have 1.03 Running on serval Amazon Fire TV Systems But it will not run with the Amazon Fire 4k The New System it gives a Dll Error .
    It Will not also run with Kodi 16.2 same Problem and the 16.2 Fix will not even install.
    Gary
  6. #26
    Apr 2015
    Quote Originally Posted by loschg View Post
    Gary
    Same problem here.
  7. #27
    PWA aCiDjEsUs's Avatar
    Jun 2015
    On a mote of dust suspended in a sunbeam...
    Well After all of these changes going on I moved from the Stock pvr.stalker to The Ninja 0.8.4
    Got everything working But the Time zone again. With the Old I was able to pointing it to the Right
    Database.
    Changing the Time zone did not help Still one hour Behind..
    Also in the settings xml there is a Line setting id="xmltv_file" value="1" Again This did not work.
    Just a Note I am in Chicago and Using the Amazon Fire TV
    Any One got this Working For CST
    Gary
    I just noticed that after the maintenance my EPG is also off by an hour, didn't change anything in the settings. Maybe it's something on their end. I got the same setup as you AFTV and I'm in the same city, before the maintenance everything was working fine. I'll give it few hours and see. Also in pvr stalker client I got my settings set to prefer XMLTV.
  8. #28
    Jan 2016
    Gary
    Interesting as my StalkerClientNFPS1.0.1 works fine in KODI 16RC2. I think I will keep it and not upgrade to 1.0.3
    I've found that ScNFPS 1.0.1 or 1.0.3 works better in Kodi 16 and Sc 0.8.4 works better in 15.2
  9. #29
    Jul 2015
    Yes I Do
    psycon,just sent you a pm with logs please help
  10. #30
    Hello dara i changed the ip address and downloaded stalker client nfps 103 but it keeps saying on the config page that its 084 and i keep getting authorization failed retrying i cleared most of the database on kodi the others i couldn't delete i am using kodi 15.2 what am i doing wrong the donation number is correct but still no luck could you please help me or anyone else i would be very thankful
  1. is NFPS epg ninja remote url not working?
    By testing12 in forum EPG (epg.ninja)
    Last Post: 12-01-2016, 01:50 AM
  2. Replies: 7
    Last Post: 10-21-2016, 08:48 PM
  3. Ninja EPG & PVR Stalker Client NFPS url?
    By rossws in forum IPTV Private Server (NFPS)
    Last Post: 11-14-2015, 02:50 AM
  4. Replies: 9
    Last Post: 11-08-2015, 12:43 AM
  5. EPG in IPTV stalker not loading (using new URL **********)
    By odigokid in forum Kodi Discussion
    Last Post: 09-10-2015, 08:39 PM
