Any replace for avov fuse remote this remote is a piece of JUNK martys
Same issue here. remote is worthless.
have been using the TVOnline remote for the Fuse and works good.
It is the smaller one picture thru the link below.
Code:http://shop-can.avov.tv/collections/avov/products/ir-remotes
hi i been telling them that for days now they say they are working on so hold on will talk to them again monday this needs to be fixed im in the same boat as you
I use this remote the only bad thing is i can not turn the box on but then again i never turn it off so its a non issues unless my power goes out then I just use the oem remote to turn it on only!
Code:http://www.amazon.com/dp/B00UYCLV8Y/ref=sr_ph_1?ie=UTF8&qid=1456764800&sr=sr-1&keywords=air+mouse+remote
check it out channel change today
the remote was a piece of crap got a tv online plus the remote is much more responsive, i think it is just the fuse boxes that have that issue
