No issues here with the epg on my windows 10 laptop using the latest kodi build.
Lets Go !
Are there issues with the guide at the moment? It loaded fine yesterday, but this morning I'm getting "No information" for all channels.
what 24 or 72 hr?
i just cleared everything and loaded the 72 hr and its fine.i dont go through papiao auth(i log into server and download the file and load it as local) though so it may be causing issues.
72 hour - NFPSF3
After first No info, I cleared the data in TV and Guide and reloaded, but still ended up with No info for all channels.
It just zips through loading the guide from client in 5 seconds.
Thanks, Blackbear
==================== EDIT
If I switch to Prefer XMLTV, I get the guide, but that one is always off by an hour.
ya,the papiao authorization is still down.
Ok, thought something was up -- or down in this case.
Thanks, Blacbear...
If off by 1 hour go into the epg update configuration and un-check time offset
then guide will be fine
this thread talks about a something that isnt used any more. closing.
