you might give the STB a try, I switch back and forth, also am running Kodi 16.5 with no issues, is the service perfect? hell no, worth the money?, hell yes
What is the STB? Still reading all these post learning the lingo...
OH.Set top box .ha ha.Yeah maybe but this mx3 android box runs everything else I've tried with no problem.There has to be something that's causing this not to work.I'm sure there's other that have ran into this same problem or has it now but can't comment on my thread due to the rules.But I swear I've followed all tips & instructions & no luck.Waisting my subscription at this point.
Shut down PVR Stalker NFPS and IPTV Stalker if you have it. Configure PVR Stalker Client accordingly...
Mimick the following format in terms of the placement of numbers and letters. Of course, change the numbers and letters, but follow the sequence and positions. Make sure IPTV Stalker and any PVR's are disabled. Start with a fresh MAC. The MAC should be in this format: 00:1A:78:XX:XX:XX.
Serial: 1760631B40872
ID 1: 8345C
ID 2: 4903B
Sig: yuck1357
Ok.I want to thank everyone that responded.The problem with the channels not loading is resolved.The problem was that when configuring the Stalker Client I used a capital letter in tghe first part of the mac address & a lower case letter in the last part of the mac address.Once corrected,the channels loaded.
Just wanted to let you know I am going through the same thing and it's crazy. they change from what is working to this and the people who have really paid get no clear instructions on how to make it work.
none of this worked. Sorry
Slizzy can you relpy with the link to the Stalker you are using?
You need to be a great deal more specific if you're requesting help. You are using Kodi? What have you tried to configure...version? What was the problem/error message?
