OK i have my donation and my AVOV TVOnline+ box, are there any youtube guides or similar to help me setup please...
Thanks,
Zak
Thanks,
Zak
Try this ...........
real ez first on your tv online plus box go to server setting click on it on top right is mac address write that down numbers will start with 00:1A:79 and three more numbers next you need to go where you got your rocket or nfps or iptv66 to change your mac address for rocket its this one https://papiao.is/main/search_rocket will ask you for your donation number thats 12 numbers rocket gave you and the numbers they show you to add click on it a box will come up and bottom you should see mac adress 00:00:00:00:00 will see a phras change mac address change that to your mac address that you wrote down click done or save should say successfull change your done with that part
now on tv-online plus in server setting must be in server setting click ok on the remote a box will come up now will see
server url add http://11.iptvrocket.tv/ this is for rocket only nfps or iptv66 has there own url
next
click use credentials
box will come up add your donation numbers to both for rocket its 12 donation number same as nfps but iptv66 has 13 donatio numbers
then click connect if you follow what i said for rocket you now have tv
if anyone see something wrong on this let me know and this is for rocket donation
