Page 2 of 24 FirstFirst 123412 ... LastLast
Results 11 to 20 of 233
    Jan 2016
    I tried to install this on my Matricom G-Box Q (that I factory defaulted) running 16 beta 5.. it errored out the first few times during the install.. I can't remember where. I'll try it again tomorrow. I know that after I ran the installer a few times, it finally looked like it was finished installing, but it didn't have a bunch of the apps installed. I installed it on my android phone running 16 beta 4 on it just fine.
    In the hills
    curious as to the error... put kodi in debug mode and pm me a pastebin of the log file.
    if u factory reset after you installed kodi q16 it would have reverted to 14 again most likely..
    I get the http error 404 not found when start NFPS after putting the information into the settings.
    Jan 2016
    Yup.. I uninstall 14 and delete all the cache stuff, then do 16.. I'll do all that in a few.. it's resetting now.
    In the hills
    Quote Originally Posted by rambopn View Post
    im not sure what you mean.. where are you getting this 404 error? if your getting a 404 you have entered a URL wrong somewhere, but where? everything is preconfigured in my pack..
    send a kodi debug log. (google it if you dont know how to make a kodi debug log)
    whathaitian?/ SMok3dOUT's Avatar
    In the Shadows
    Quote Originally Posted by psycon View Post
    you can change C to F in settings>appearance>international.. just set region to US or go down and specifically set temperature type to F
    Thanks, got it... Nice "pack" clean and simple...
    Love that you don't have to scan for new content
    It just adds your new movies or tv shows automatically
    Also direct access to my movies or tv shows...
    Nice touch with the background coincides with the weather...
    Great job Clairvoyants, keep it coming
    [SIGPIC][/SIGPIC]
    ________________________________
    Sleep is the Cousin of Death...
    Stalker Client PVR Channel Management
    http://iptvtalk.nl/showthread.php?20...agement-for-PC
    Jan 2016
    So.. I brought my box into work today, and downloaded the latest nightly build (16 RC), and it worked perfectly. I'm not sure what was going on the other day. Everything is working perfectly for me.
    left field
    Quote Originally Posted by SMok3dOUT View Post
    @Psycon may I ask which weather addon is being referenced here? I'm using Weather Underground since the first install of XBMC years ago. I like that it is a bit more detailed in data it provides. It stopped working about a year ago but a fix was posted on kodi.tv and that's what I did to keep it working. Tks.
    In the hills
    openweather map.... that plugin has been troubles lately,, there is a new openweathermap extended you should. switch to... just go to settings>weather>get more.
    jsut working on an update to add that as well as a bunch of live tv plugins... will be up soon..
    left field
    Thanks, will check it out.
  1. Clairvoyance Skin Not Working?
    By mriksman in forum EPG (epg.ninja)
    Last Post: 09-08-2016, 01:28 PM
  2. Clairvoyance/Epg Ninja
    By tipriz in forum EPG (epg.ninja)
    Last Post: 05-02-2016, 04:25 PM
  3. Clairvoyance
    By dotsadie in forum Kodi Discussion
    Last Post: 04-19-2016, 10:21 PM
  4. Clairvoyance build video choppy
    By rocket77 in forum EPG (epg.ninja)
    Last Post: 02-19-2016, 01:19 PM
