Results 1 to 6 of 6
    Jan 2016
    Yes I do
    Unhappy Need help with IPTV Stalker on NEXUS Player Kodi 15.2
    Hello well I took the plunge and made a donation to IPTVStalker however my efforts to configure the pvr client has been very challenging.
    I have a NEXUS Player running Android v6.0.1
    Kodi install is 15.2 (d/l off Google Play)
    Fresh install (but I would like to run "The Beast 14.1" wizard for added mods etc...
    The problem I am having is that I cant use the Stalker NFPS client because I get the dreaded "can't load DLL" error, so no joy getting this to work in a almost foolproof method. I tried a more advance method using the IPTV Stalker add-on but I cant get EPG service to work. The NEXUS Player is my main source for TV etc... so I really like to get this configure with working EPG. I already tested the pvr.stalker.nfps-win32 client on a windows machine and got it to work with my subbed donation (I can download channels from IPTV Stalker and EPG integrates with Kodi). However on NEXUS Player using "plugin.video.stalker 9.0.21" I can't get the Guide to show up within Kodi no matter what I do. I can download the channels and login authenticates but guide data is all blank no matter what I do.
    1. So far I can use this add-on to download channels: plugin.video.stalker 9.0.21 (no guide data )
    2. I can't use pvr.stalker.nfps-android-arm client because I get the "Can't Load DLL" error. The modified Android version of Kodi 14.1 that was posted mid last year as a work around to fix DLL error is no longer available.
    Can some one help me figure this this out been stuck for 2 days straight, read lost of posts but cant figure this out.
    IPTV Stalker 9.0.21 works with the iVue guide, not epg ninja.
    You can configure the PVR Stalker Client that is built into Kodi 15.2. There is a lot information here for configuring it.
    Jan 2016
    Yes I do
    OK thanks for the tip.
    I came across some info on setting up the service using the built in client but I cant seem to find it now. By using the PVR Stalker Client built into Kodi is that all I need or do I also need a pvr like simple IPTV?
    The built in PVR Stalker Client is all you'd need. Here is a thread dedicated to getting you up and running with it.
    http://iptvtalk.net/showthread.php?6...Kodi-Built-in)
    Jan 2016
    Yes I do
    OK I will read up and give this a try.
    tux tux tux
    Jul 2015
    in my head
    its maybe worth mentioning that serial must be 13 chars, device id's can be the same, but signature needs to be different and 4 chars is enough for both dev id's and signature.
    “there is nothing wrong with being insane, as long as you know it yourself.”
  1. Stalker NFPS Version for Nexus player
    By Ozzman in forum PVR Clients
    Last Post: 02-09-2016, 12:02 AM
  2. Nexus Player freezing
    By andmaster in forum Other Devices
    Last Post: 01-11-2016, 03:25 AM
  3. Nexus Player - STB Emu HowTo
    By dixeflatline in forum Other Devices
    Last Post: 07-05-2015, 05:28 PM
  4. Nexus Player
    By novaman in forum IPTV Private Server (NFPS)
    Last Post: 03-02-2015, 03:22 AM
  5. Setup IPTV Service on Nexus Player and watch Live TV
    By mejdam in forum Android TV Boxes
    Last Post: 02-10-2015, 08:48 PM
Tags for this Thread
