Im using kidi 15.2 recently install pvr stalker nfps, load channel perfectly but, dont load the guide. The program said unable to load guide. Help
its because you tried accessing it to many times in a row 2 or 3 and the server will put a temporarily ban on your ip for a few hours, the server does not just refuse you but throws back a error, in newer clients this shows up as an error as well afaik. try wait a few hours.
“there is nothing wrong with being insane, as long as you know it yourself.”
Tank you
Set my sisters client yesterday and it would load the channels but not the guide. I found several errors in the string for the guide url. Corrected them and it loads the guide.
how might I correct this myself?
so far, every person who cannot get it workingi and sent me their log is either making typo, not putting their donation number in at all or something else silly.... if you cant get it working. erase everything and start over.. actually read ( and follow) the steps in the how to thread...
I'm getting the same error messa 'Stalker client unable to load guide'.... I checked everything twice and there are no typos. I'm trying to setup IPTV66 on Android box with Kodi 16.1 installed. Where can I get further help?
Getting same message here. I set up Stalker client first. Then I installed ********** updater service. Same donation info etc etc .. Did not check load stalker NFPS from this setting etc etc.. left them all blank. Afraid I will get shut off for too many ip requests. What is the best way nowadays for iptv66 everything is all so conflicting... Thanks.
