do you occasionally get buffering issues when playing some TV channels? is that an issue with iks66 or is that a software issue on my end? will that buffering fix thread sort it out
Just for your info... 16.0 worked in overcoming the PVR dll fail issue i had but the TV guide install failed on an old duel core minix x5 mini i just tested. So TV but no guide. The latest 16.5 kodi doesnt work.
you have two options if you cannot root and get the cannot load dll error..
1. use pvr.stalker instead of pvr.stalker.nfps, its built into kodi already, and works..
oh yes been working on this for two days thank you so much
Its saying cannot connect to thenspg ninja link.
i can't find this folder... /data/data/org.xbmc.kodi/cache/apk/assets/addons/
With es file explorer. Why 777 permition don't let add changes on nfps stalker.
