can someone please test **********/kodi.apk on a device that gets the dll error normally... its kodi 16 beta 4 with pvr.stalker.nfps included.
Just doing backup of my 15.2 and will try kodi.apk from **********
Using Kodi 16 beta 4 with the latest pvr stalker finally works. I've used the kodi package that Psycon shared above. Been trying to get it to work all day. You might have to get a new MAC address if you have previously used it with the IPTV Stalker add-on. Good luck!
By the way, I'm using a non rooted Nvidia Shield
ok then so it works. good to know. I will package more as the full betas come out... the downside to using these apks is you can no longer update using official kodi apks so be warned
Besides having pvr.stalker.nfps packaged together with Kodi in this apk you created, is there any difference in doing it manually i.e. downloading Kodi from kodi.tv and then downloading and installing pvr.stalker.nfps from **********?
i only made that apk for people having the "could not load dll" issue and cant root..... if you can root, do the steps in the OP, it will be better for you in the long run possibly (as the apk will rely on me to keep updating, which i likely will, but it may bore me, its really simple to make, i juse used ab app called "one click signer".. added the plugins files to the addons folder inside the apk using 7zip, then resigned with one click signer..
if you do not have the dll issue, install normally from kodi.tv and add the plugin from **********, dont use a modified apk, it prevents updating using official apks.
I have the "can't load dll" issue. So only this custom kodi.apk solves this issue?
works fantastic psycon thanks so much. i was so upset about the dll error i was ready to switch back to my aftv stick.
what custom build do suggest installing with this? iwas using TV-addons and it was alright
