yes leave login blank for now, you do no need ivue anymore, the epg will be fully integrated in kodi as it should be
put in serial, and all that stuff as in iptvstalker.
you need to use a different portal url than iptv stalker, depending on your version of kodi, i posted them below.
enable it first time it will fail i dont know why. but just tre-enable the addon or restart kodi.
here is a rough guide:
http://iptvtalk.net/showthread.php?9...Stalker-Client
portal urls:
for kodi 15.2: (isengard)
NFPS - http://11.iptvprivateserver.tv
Rocket - http://11.iptvrocket.tv
IPTV66 - http://66.iptv66.tv
for kodi 16 beta (Jarvis)
NFPS - http://portal.iptvprivateserver.tv/stalker_portal/c/
Rocket - http://portal.iptvrocket.tv/stalker_portal/c/
IPTV66 - http://mw1.iptv66.tv/stalker_portal/c/
when you got that running you need to setup epg, you can leave it blank but then you only get some channels.
look in the epg section of this guide, this can also help you setup the other stuff if it fails:
you can also look at number two link you posted, basically you need to put a customized url in the xml guide field that goes like this:
nfps or rocket : https://papaio.tv/main/EPG/mac/00:1A:7x:xx:xx:xx/donation/xxxxxxxxxxxx/fname/<guide>
iptv66: https://iks66.tv/main/EPG/mac/00:1A:7x:xx:xx:xx/donation/xxxxxxxxxxxxx/fname/<guide>
Replace "<guide>" with the following:
NFPSF1 - English
NFPSF2 - English, non DST
NFPSF3 - Full
NFPSF4 - Full, non DST
replace the xx with your mac and donation.
i know it might look overwhelming, but if you take it step by step, and look at the guides its really not. i just added some caveats.
after you got the hang of it's as simple as iptv stalker and ivue.
