Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    TV Addicted eureka's Avatar
    Fawlty Towers
    Quote Originally Posted by Deana3333 View Post
    Idk what I'm doing wrong did all that reset device everything loads channels ect the click live tv then opens up when I pull up the settings on the side I click guide n it says no guide entires if I click channels then all the channels pop up with the channel number but no guide mmmm
    Have you chosen View: Timeline?
  2. #22
    Yea
    Quote Originally Posted by eureka View Post
    Have you entered your correct timezone in the pvr client settings in the form of Continent/City?
    You can find yours here:
    https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
    Ok gonna try that but no I have not
    America/New_York will put you in the proper time zone.
    Ok thanks a lot!!
    Yes I click view on the top of settings but just blank screen
  3. #23
    After making sure View: Timeline is set properly as Eureka suggested, try scrolling left in the guide to see if there are listings for earlier times. Usually when the guide is completely unpopulated, you do not see channel names and logos as you mentioned seeing.
  4. #24
    Moved this massive hijack to its own thread.
  5. #25
    Yea
    No nothing I even tried clicking different opinions on the view settings and one of them says on the view:now brings up no guide entries
  6. #26
    Yea
    Thanks for all the help trying get this to work I will mess around n try to figure something out thanks guys!!!
  7. #27
    Jul 2015
    do you have the epg set to xml only? if so switch it to xml preferred then go to tv section turn tv off then guide section clear data 3 times restart kodi turn tv back on should fix it. I just duplicated your problem this solved it
  8. #28
    Fawlty Towers
    Sorry about that Dara!
  9. #29
    In the hills
    use pvr.stalker.nfps, not pvr.stalker built into kodi... much easer to get going.
  10. #30
    Yea
    Quote Originally Posted by psycon View Post
    All sorted thanks everyone! I'm sure y'all are glad to hear that. Srry guys
  1. IPTV Stalker Plus 10.2.3 EGP PVR Stalker NFPS For PC
    By Gilles1945 in forum Kodi Discussion
    Last Post: 12-06-2016, 02:28 AM
  2. IPTV NFPS on AVOV TV ONLINE + KODI IPTV STALKER
    By waqarkhan197 in forum IPTV Private Server (NFPS)
    Last Post: 04-12-2016, 02:50 AM
  3. iptv stalker nfps
    By MONTY32UK in forum IPTV Private Server (NFPS)
    Last Post: 12-17-2015, 11:27 PM
  4. Iptv stalker nfps
    By androidblack in forum IPTV Private Server (NFPS)
    Last Post: 07-18-2015, 08:33 PM
