ok if you doing this Here is an easy to follow guide for installing the IPTV Stalker Add-On for Kodi.
Download IPTV Stalker for Kodi Zip and save to a location you can easily access from your Kodi device
Open Kodi
then to this Install from zip file
then it said to Navigate to where you downloaded the zip in the first step and select plugin.video.stalker-master.zip ok if you go back to picture where i put it and you click on this file it don't move so how you get it to go to your file manage on you box my ? jc cell
