Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Quote Originally Posted by Lowteck View Post
    Do you have a cat5 cable plugged into the box?
    Thanks Lowteck
    If you have a cat5 cable plugged into the box WiFi will not work
    Two of the greatest qualities
    to have in live are:
    PATIENCE
    and
    WISDOM
    Member Flameangel's Avatar
    Apr 2015
    Yes I do
    Yes it's directly connected to the internet via an Ethernet cable.
    Today only happen once
    unplug your cat5 cable to enable wifi
    or if you use the cat 5 cable check and make sure your Ethernet is set to DHCP
    the ip address and everything should populate and your internet should work
    PATIENCE
    and
    WISDOM
    Jan 2016
    My wifi is mac address lock, so I need the mac address of my AVOV_TLP device.
    How do I find it?
  1. How do you enable the audio on a channel
    By legsdiamo in forum BuzzTV XR/XRS4000 - XR/XRS4200
    Last Post: 06-10-2021, 04:49 PM
  2. How to find out if someone is using My Wireless Network
    By Kimbo in forum Routers & Networking
    Last Post: 04-24-2017, 11:39 AM
  3. How to enable recording / DVR?
    By AeroDunky in forum Amazon FireStick & FireTV
    Last Post: 03-05-2016, 07:28 PM
  4. Can I enable 2 pvr's?
    By matrixebiz in forum PVR Clients
    Last Post: 02-04-2016, 03:01 PM
  5. Wireless Network USB antennae/adaptor
    By Scanner in forum IPTV Private Server (Rocket)
    Last Post: 06-13-2015, 02:34 AM
