how do you get cyberghost to the Fuse. Give us a hint please. You said before to use the setup for Linux but the Avov is Android.
its simple
i just bought a vpn today wish i saw cyberghost its cheaper
in the fuse
go to the micky hop
then settings
there is a vpn section
put your vpn info in then hit connect and your done
go to site enter username password then select add new device then linux router ext then a page will come for credentials for device i put avov fuse you will get information you need to enter in vpn setting on avov
nothing hard to add a vpn will free ghost work
can someone make a video on this box please?
http://iptvtalk.net/showthread.php?1...e-server-setup box is ez to use
hey ast thanks for the guide! do you also have a guide for the ATSC/DVBS2 thanks
In the Stickies:
http://iptvtalk.net/showthread.php?1...-what-are-they
testing avov fuse on cyberghost 5 work very well very impressed on performance of this avov fuse
Thank you very much captain kangaroo for the link but I'm still confused on how to set this device with the ATSC. That link you provide just explain the diffent tuners not how to set them up. Sorry for my stupidity, maybe if I had a box I could understand it better. Also where do you guys by the tuners from thanks
