Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: Fuse
    Copernicus Crater
    That's the tuner i ordered not sure what I am going to use it for LOL
    lots of fta sats if you have the right dish and probably a linear lnb.
    Not 100% sure though
    Copernicus Crater
    Just got an email from Avov:
    We are waiting for ATSC. We have DVB-S2 at the moment and can send you either or if you wish.
    looks like it is a DVB S2 tuner so it will pick up any sat really, linear or circular. Won't find any free content thru Circular thou, you'd have to go with Linear.
    Linear sats need different LNBs and usually larger dishes then Circular sats.
    Not to be confused with Ku-band and C-band.
    C-Band is all linear sats, while KuBand is both Linear and Circular.
    AT lygnsat, you can tell which are linear sats by the polarization they use.
    Linear would be Horizontal or Vertical while Circular would be Left or Right.
    Cband have 4 digits in the TP frequency while KuBand have 5 digits in the TP frequencies (actually they are more digits but they only show 5 at lygnsat and on our receivers show 5 as well).
    Motorized dish is best with linear sats as each sat may only have a couple worth while channels (as per preference), so in order to have a selection of some channels, it's nice to have access to all sats on the clarke belt
    Hope the Fuse has motorized settings
    Quote Originally Posted by Captainkangaroo View Post
    i'm still waiting for my DVB-S2 tuner
    i guess i'll have to shoot them an email
    La Nada en el todo nada233's Avatar
    so far its working excellent and same as other waiting for the dvb -S2 tuner.
    For those who have a tuner, does it support mpg4 or the Dish turbo?
    DVBs2 is used by both Dish and Direct in up-linking but hasn't reached the consumer level yet, it may never reach it, who knows??
    HD stands for Harley Davidson 4wheelin's Avatar
    i have been playing abit with fuse here ,it seems very nice and more addons ,i see a fair amount of games with it also ,not into them myself but definitely a nice box.
    so would you say a motorized dish is the way to go on the fuse dvb-s2 tuner never tried one
    The Fuse has the DiSCqE 1.0 and 1.1 and 1.2 and 1.3 functions
    With the 1.2 and 1.3 being the Motor Mode, so yes the FUSE has motor control
    There are no Circular sats listed in the FUSE's Satellite List, but you can add sat of your own. Circular sats are all encrypted thou and the FUSE does not do IKS
    The FUSE has most all other sats and they are Linear sats, Ku-Band and C-Bnad
    The Satalite setup menus are well put together on first look.
    I will get it connected to motor a little later and report how that works.
    Just looking at the Kodi now and the Kodi installer just started.
  1. fuse
    By perhal in forum aVOV Fuse
    Last Post: 01-15-2019, 11:19 PM
  2. Fuse
    Last Post: 03-30-2016, 06:57 PM
  3. Fuse
    By catz in forum aVOV Fuse
    Last Post: 03-27-2016, 11:50 PM
  4. Fuse
    By starRyder in forum aVOV Fuse
    Last Post: 02-19-2016, 04:42 PM
  5. apk's on fuse
    By timezone12 in forum aVOV Fuse
    Last Post: 12-28-2015, 01:50 AM
