Results 1 to 10 of 20
Thread: Remote control
    Remote control
    why is there 2 power buttons on the mag254 remote control, i would assume you could control your tv with it... But i cant find where and how to program it for my tv.. Both of the buttons turn off my mag254. Maybe i missing something , but i cant find that information
    Super Moderator BIO's Avatar
    The mag remote is not an universal remote, nor is it programmable. Take a look at the paper guide that came in the box, it says the blue on the left is "Programmable Selection". The programming of that button is up to the server operating the portal, at least I think it is?..
    sure is on that info need glasses to see it
    Naa asft, I put a pic of the remote in the setup thread so it can be zoomed in for us that need binoculars to read
    You're on your own for the rest though
    Attached Images Attached Images
    TV Addicted dreamscape's Avatar
    To program the buttons do the following:
    • Press the «On/Off» and «A/V» buttons at the same time and hold it for 2 seconds. When the green light of the «On/Off» button will stop blinking and will light steadily, it means the RC is ready to learn.
    • Press the button you want to «teach» — the green light will start blinking.
    • Place the infrared lamps of two RCs opposite each other and press the button on the RC of the other device, the function of which you wish to copy on AuraHD Plus RC. Hold for 2 seconds.
    • After the green light two quick blinks you may continue programming other buttons.
    • Repeat the procedure described above for all buttons you want to program for controlling external devices.
    • Press the the «On/Off» and «A/V» buttons to save the programmed data; the green light should fade off .
    Reset
    • Press SETUP and OK button at same time and hold for 2 seconds red LED will flash 5times. Reset is done.
    Running 150mb cable broadband & mag254 :cool:
    Great job dreamscape, I did not know that and stand corrected.
    Going to make your post and pic a sticky for ya
    what green light are you talking about -- i dont see one on my rc
    Quote Originally Posted by BIO View Post
    Hiya BIO, thanks, can you change the title please though, only mag 254 new remote as far as I know, i.e not 250 one....
    yes thanks going to save that on my computer bio didn't even see that getting old
  1. remote control app
    By uri3l in forum Dreamlink T1
    Last Post: 03-31-2017, 12:26 AM
  2. Remote Control
    By grodri1972 in forum aVOV TVOnline
    Last Post: 06-03-2016, 06:39 PM
  3. remote control
    By normski2 in forum IPTV STB Emulators
    Last Post: 03-15-2016, 11:08 AM
  4. remote control
    By the2deez in forum aVOV TVOnline
    Last Post: 01-31-2016, 10:50 AM
  5. Replies: 11
    Last Post: 10-26-2015, 01:53 AM
