you didnt get from us did you
think you got from a reseller bro if you did your sol till he can fix you or is that your old one
It looks like the mac address was removed from my post above but trust me it was listed there, sorry if that was a no no... I don't think I need to change it if it is already on record do I?
told you your chit out of luck till you can change that address did you get it from iptvrocket.is that donation
Bought it online direct from AVOV Technology Inc about 5 or 6 weeks ago and was trying the free side of it but got nothing but freezes so I broke down and got a rocket but so far that rocket isn't firing...
Change IPTV MAC Address.
Use the Mac addy found on the avov, found either on the underside of the box or it should be in the TVOnline menu screen, top right corner.
don't post mac addies in open forums. It's for your protection.
Will changing that Mac addy to the addy that shows on your avov be the answer?
It should show the MAC addy when you open TVOnline menu. Or it'll be in one of the system menus.
look do this pm me your id and mac address you have now and get the one from the avov box and i will try to change it for you only pm me that info not here i can do that much for you its try and iptvrocket.is will never send you a mac address give me what rocket sent you
I will try to change mac address, I backed out of it before because I was convinced that it was already assigned to me. I will be using the same address I used when I made my donation because it's the same address I still have on my box
you are 100% right all is good with that
need to go to setting
then server setting
then server 1 click on it add at the url http://11.iptvrocket.tv/ and you should have tv
I tried that as well, also already did the factory reset still with no luck... Gone back to AVOV customer support and waiting on reply there... In the mean time one more question... I made a $80 donation but now I am seeing $105 and $70 pricing and i just wanna know if I bought the right rocket, the email confirmation looks good but should I have gotten the $105 thing???
