Blackbear... you are the man. All is well.
Provider only is the way to go.
Thanks.
Thanks.
the regular NFPSF1-4 files should also be fixed.there are no lunger ant fullutc files(that idea didn't workout at all).
if provider only guide preference is showling correctly for you then NFPSF2(English) or NFPSF4(Full) should also show correctly now,i applied the same fix as I did for provider only today.
btw NFPSF1-4 is only used when you select xmltv only.the epg url is not used at all when you select provider only.
provider only gets the epg from the nfps server rather than epg.ninga.
its the same epg info but I think the program description is not as detailed,i've never used it.just going by what I seen people post.
I had to revert the changes I had made for NFPSF1-4 so continue using provider only for those that have the 1 hr issue.
I like provider only... nothing to think about or enter in. Thanks for keeping it SIMPLE.
Looks like the guide is off again. Have any changes been implemented?
Same. Seems to be problem after problem
The guide has been showing the correct time once again, for several days. Thanks again for the great guide, and for maintaining it!
