Results 1 to 6 of 6
    Nov 2015
    Problem using MAC address
    I just signed up for a 1 month subscription at iptv66.com. I signed up without a MAC address. When I got my email with the route number I went to https://iks66.tv/main/search/ to change my MAC address. It was 00:00:00:00:00:00 and I made up my own address in that format to put into IPTV Stalker in Kodi. The MAC address changed correctly and shows up when I enter my route number athttps://iks66.tv/main/search/. I took this mac and inputed it into IPTV Stalker for the custom MAC address. I then used http://66.IPTV66.TV for the url. I did not change anything else. I cleared the cache and whenever i click on NFPS I get an error that say's "HTTP Error 404: Not Found". I went to https://iks66.tv/main/search/ and successfully changed the MAC address and then inputed it into Stalker, cleared the cache and I still get the same error. Can anyone help me out?
    Thanx,
    Michael
    depending on which stalker you are using, you may have to use the portal. format...see the kodi forum
    Nov 2015
    It works correctly now. I had to change the URL to http://mw1.iptv66.tv and everything works absolutely great. Thanx K00lKatT for steering me in the right direction.
    you're welcome....
    Jan 2015
    KoolKatT, I have followed all the same thing, but my channels last 30 second and it goes back. What I need to actived the staker.
  1. I have problem to add mac address
    By Warrious7 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-04-2017, 09:49 PM
  2. Mac Address problem
    By edwinvj in forum Amazon FireStick & FireTV
    Last Post: 02-04-2017, 01:03 AM
  3. MAC address problem
    By Monrreal in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 12-02-2015, 03:37 AM
  4. MAC address problem
    By Racso83 in forum IPTV Private Server (Rocket)
    Last Post: 11-14-2015, 10:30 AM
  5. Problem with mac address
    By Winchy6 in forum IPTV Private Server (Rocket)
    Last Post: 08-18-2015, 05:11 PM
