Will Dreamlink Android Smart TV Box be supported as Avov vixo 01 ? I'm confused between both ... any suggestions will be appreciated .
sorry no only avov and mag 250 and 254
ASFT,
thanks for your answer, and If I may ask which do you think better Avov or 254, any recommendation ?
they say the mag 254
I hope DL gets it figured out.
I really enjoy the Android box.Picture is great on it.
I liked the Dreamlink Android box but the controls Google has over it made me wonder who owned the box. I wound up installing a VPN and using it exclusively for Netflix but when I had enough of that, I wound up giving it away so, I'll be looking hard at the next DreamLink Android box before I go all in. I'm not a fan of Google Playstore.
