the manual shows how to uuse it oon a ssmart tv
Remote similar to one I have had years from Minix, but of course this dedicated to buzz with more buttons, looks great, will order when out in UK.
I just noticed something kinda unique with this remote.
When you use the Mouse Pointer button on the remote it brings up the mouse pointer onscreen, nothing surprising with that , but....
You can wave your remote around and the mouse pointer moves on-screen the same as the movements you do with the remote.
Moving the remote till the pointer hovers over a selection and then press OK and that works :)
No more cumbersome mouse pointer moving with the arrow keys :)
I got the remote today and found instructions.
So I did the remote learning feature and managed to get the remote to power the TV and change the source... but now many of the buttons don't work for the 3000 anymore.
Home, channel up and down, return, volume...
Is there a way to reset it?
I do not see much documentation about an actual reset function. Seeing lots of info about resetting or recalerbrating the air mouse.
I did see posted on a Playstation board and with one of their air mouse remotes that after waking up the remote (press any button) then press and hold the Cursor Lock button for 3 seconds and that factory resets that remote (erases the IR commands that you entered).
That is a different remote thou (PS1 and PS2 air remote).
Be careful of what you press thou, actually of how many buttons you press at same time. Pressing all the arrow buttons at same time may mess up the Air Mouse and the mouse will drift by itself.
But try the cursor button for 3 seconds.
Does this remote need line of sight like the original remote to the buzztv to work?
