Just picked a n brand new XRS 4000 and can't wait to start testing it but getting "Device not authorized" message after completing initial setup.
Any one else here with the same problem?
thanks in advance!
thanks in advance!
reboot the xr4000
Reboot reboot takes a few time’s
Or wifi connection to 5G
Just sayin
c/p
not sure if its for xr4000 or xrs4000 or both.
device not authorized fix.
Using the Remote press the on and off button while it in the file download..
The box will Factory Reset its self
Leave on the homepage until it asks for a reboot
then the new file will load!! (3mins or so)
do it on your own risk.
I saw this suggeston, its not it. it dosen't get to the point where its trying to download the file. This happens as soon as you go through all the initial setup screens.
This is the XRS, not the XR.
[QUOTE=crazed 8.4;262208]reboot the xr4000[its the XRS not the XR, rebooting dosen't seem to work.
I doubt there would be any difference in the XR and the XRS with an issue like this.
If Ryu's suggestion will not work, look again at Rinny's
In Ryu's suggestion there is a Factory Default included, so do that too. The Default will then lead to a automatic reboot.
