Can't find a 'MANAGE' tab. When IPTVextra opens do you mean "Trak Manager". If so, that is the function that does not work, and the reason for my workaround.
Can't find a 'MANAGE' tab, when IPTVextra opens. Do you mean "Trak Manager". If so, that is the function that does not work, and the reason for my workaround
Kens... The mediainfo screen shown on your screenshot is totally different from what I get in my Mediainfo screen..
On the Information display bar, I get :
Play, Library, Chapaal, Your Ratings, Star, Add to list, Show lists, Already rated, Trakt Manager(which does not work), and Settings
Manage does not appear
Also, on the bottom, I do not see the cast members (in your screenshot), I get recommended movies from TMDB, or trailers.
Like I mentioned previously, you are using Wraith/ Chapp.. Addon that Overwrites the Extendedinfo Script from Kodi.
This is where the problem is being caused.
Things will not work as I described because my Addon tries to excess the Kodi Script and the Modified Wraith Script is run instead.
If you read the Info screen for Wraiths Extended info script, it explains what has to be deleted if you want to use kodi's extinfo.
Just FYI
Uninstall Wraith
Uninstall Chapp
Uninstall Extended info script
Then install from kodi Repository the real extended info script.
Thanks for the Feedback relating to your successful outcome.
kens thanks, you are the master
Kens... new issue with the extended media setup..
With the Blamo Repo now defunct... I have 3 addons from there, so I installed two new addons as a backup'
I installed Yoda (in Supremacy Repo), and Gaia(in the Gaia Repo). In my IPTVextra setup before, I had 4 addons available for PLAY functions.
After installing Yoda and Gaia, they did not get added to the IPTVexra play list. Still have the same 4. Don't know how to add the new ones.
And if I try to select a movie in these 2 new addons and select them for extended media info, I get an
error message saying "error-error prepare data - no media".
Tried to un-install and re-install IPTVextra. NOW I am getting this same error ("error-error prepare data - no media") when I try to open media
data on the IPTVextra VOD movies also.
Here is a log for diagnosisCode:https://paste.kodi.tv/inigeselir
Hard to understand what you are saying??
That specific error is when you select an item but the data in the addon database is not correct.
So I installed Yoda from repo, opened it (it is a copy of Exodus by the way), selected a movie to get Media info and had no problems.
Checked IPTVXtra VOD, also no problems.
For the other one, i could only get Dimitrology, no Gaia.
You will have to check the Kodi Error log and see what is causing the problem.
