Trouble with Channel Order after new Update ? ... from profster
I found this in Sam1's recent thread.
Thnx profster and donaldb and Sam :)
Quote:
Originally Posted by
profster
I believe the problem is in the name you use ie for NFPS ........ after server.tv add the following with no spaces ie.
hxxp://p1.iptvp......server.tv/c/index.html that is the full path and might be needed to get the server to work.
donaldb
Thanks profster this worked for me.
Should be a sticky!
after server.tv add the following with no spaces /c/index.html
You can also find the full server URL at your perspective service websites, just log on to your code and it will show there in red print.
click the link below and send profster and the guys a thnx
http://iptvtalk.net/showthread.php?3...345#post233345
