Does this addon work on Kodi 17.1?
I don't think it has been tested with K17 yet (i.e., Couch Potato hasn't...I'm not sure what Dara was using), but I have a feeling it would work. Install it and see. The worst that will happen is it will not install or it will not launch. If launch failure occurs, you could simply uninstall it.
Ah, ok... When I first looked at it, it was not a sticky.
4wheelin did it... I was a bit tippsy early this morning or last night when this was posted and did not wanna mess it up, so 4wheelin was online and he had already had the thought in mind, I just pushed him :)
Cool... Watch out for the hair of the dog :)
Works perfect on kodi 17 even the epg with simple client nice work
No vod but heck its working on all channels with epg.
Thanks for the stiky mates :)
it really helps me to read any reports for solving all the related issues
Quote:
just for my curiosity, I installed the krypton for testing my addon
and... Taddaaaa!!! it works!
http://s10.postimg.org/n3n4w7xmx/krypton1.png
http://s18.postimg.org/e6k7bcjrt/krypton2.png
you may try my new release (v1.0.1)
i have made some changes with the codes, most of them are related to the donation based account
I've already meantioned the issue in my notes #2
sorry I can't fix it since it's related to the server side which is beyond my control
a new release
v1.0.1 (2017/03/27)
download link is on the first pageCode:- Fix some issues related with "Donation Based" accounts:
- Add 'ALL' item for the genre options
- Redefine the channel numbering (all foreign channels numbers are started with 5000)
- Fix language filter
- Add adult contents filtering for M3U playlist
- Create custom list file for any available portals
The list can be customized by editing the 'Kodi/addons/plugin.video.potatoTV/resources/portals.list'
- Fix few minor issues
