Should we use Kodi with IPTV Rocket, NFPS, 66 ? Do you still need Kodi? What are the alternatives if any?
Thanks for the answers and comments.
I believe that is a personal preference more or less ...... honestly you have a lot of channels with all three systems , read / learn here -> IPTV Live Channel List
Don't have a VOD - Video On Demand List - because it's always being updated along with Tv Series ......
I can't really answer your question(s) about kodi , because i really don't use it .. it's been years ....... i guess you could keep as a back up , what i am saying is you have a lot of choices already with the three services as is .
Maybe i am confused are you connecting through kodi ?
Do you have a STB set top box ? or are you using a PC personal computer ..ect ..ect ?
Here is kodi instructions below -> -Kodi-Discussion
You see the two stickies talking about at the top , is that what you're talking about ?
Thank you for the reply.
I have a Buzz box but have Kodi on it as well that I use to load APK files. Is their another way to load APK files? Thanks
I am pretty sure there is , not sure what buzz box you have .. i would assume they all open Android Packed Kit files ....
you can open a thread if you want in the sub forums or tell me what version of buzz box you have , maybe someone else can be assist you with loading them ... i have the xr 4500 .. if you need help i am sure we can figure it out ...
Buzz Sub Forums ->-BuzzTV-Box
what model do you have ?
installing apk
http://iptvtalk.net/showthread.php?3...-AppInstallers
There are some 'remote' channels seen thru liveTV
These channels are not hosted on the papiao servers. In fact you can view these channels without having a papiao active account(code). But you'd need the channel access first in order to get the channel info in order to view it outside of papaio code. So you\d need a papiao code in order to access the channel info
THe PPV channels are like this , and many more.
kinda a Catch 22 situation :)
