I can play VOD movies with internal or external player, but when it comes to TV series the myonlinetv2 app crashes, if external player is chosen it doesnt give option to select player, just crashes.
Did you update your box? See if any update is available. If not then try to factory reset box then try again.
Yes I did update the box with latest firmware and software. I will try to do factory reset as I havent tried that yet. Thanks
yes try factory reset then let us know please.:)
I did that this morning with no joy :(
the z8 plays TV Series without crashing... tested last night with z8
Maybe your z8 resolution is set too high for your TV , which causing the crashing, but even when I set this too high here, the mol2 does not crash but the TV picture is interrupted often and randomly.
Try adjusting that setting for results
No crashes here either. I did boot once and it said Resolution wasn't compatible so I hit the Resolution button and all was good.VOD fine here. No crashes
I can't play any VOD's on the Z8. New to the Z8 but not Formuler. Z7+ isn't playing VOD's either. Server related?
Been testing this since you posted and seems that VODs will not play thru Playlist Portal either on this z8... the LiveTV thru m3u Playlist Portals work fine thou.
Have not tried other methods on the z8 yet (other then m3u Playlist method), but VODs are fine thru the Buzz box via MAC attached method.
Seems strange because VODs under m3u playlist portal worked fine on the z8 the last time they were checked on :eek:
Thanx for confirming my suspicions! One may think that this could possibly be software issues? Please post your findings.
