Channel list can be seen thru the link posted below.
The list is updated daily
https://iptvprivateserver.is/templat...nels-table.php
You could setup that Dreamlink in such a way that you can have access to either EPG and also the EPG which the service supplies.
Set that up correctly and then its a simple click of a couple buttons on your remote to switch between them.
The T1+ is a bit outdated, but is fine.
The Dreamlink T3 is their newest model and it does even better with server setup scenarios
