stalker client help
If this has been ask then my apologies,,, been running my T1 with dol , been great but been a while now since I used kodi stalker setup
1, can I still use built in stalker client without now needing signature, device id's ? and is there a url that we can still use with it to get an epg?
2. I see that there is also the potato version but seems to be pretty complicated to set up especially with matching sids
so for me option 1 is what I am looking for but if it no longer has a working epg then I guess potato is my only choice
does yahyabell still work for stalker client?
any help and direction would be a great help
I did notice Kens has a how to for potato set up and sid but looks a little much for me
far as I can see curgs, you are doing fine... You navagated these forums, you found choices, you made decisions.
That Dreamlink has its own onboard middleware - emulator... no need for IDs and the such, just your log in credentials
And Potato aint really that complicated, might seem so, but Couch Potato makes things pretty easy once you get started with his method
Thanks crazed. Just reading kens workaround to get guide going again with a new m3u ,,, looks like i need to make changes in it to use rocket since kens is for nfps,,, see what i can do
