Thanks crazed that fixed it for me. Had another issue though where when i exited the finish iptv notification box stuck....I had to reboot to fix it
Is the T1+ getting a new update too?
check for updates today guys.
The T1 Plus will show an update waiting to be loaded.
DOL2 App version V1.09.35 - r1724
XC Portal > Fixed VOD loading issue
XC Portal > Fixed Live TV and loading issues
XC Portal > Added xmltv EPG feature
M3U > Fixed VOD crashing issue
M3U > Added xmltv EPG feature
VOD > Improved appearance of subtitles. White font with black shadow.
Fixed DVB subtitle display issue
Fixed 'Stuck in Standby Mode' issue
Fixed app startup delay issue
Overall EPG performance improvements
General bug fixes and performance enhancements
Have found so far...
-portals load faster
-an edited m3u Playlist on USB loaded into Playlist Portal is working again. VOD categories are seen and fully functional, as edited.
Great update features. What exactly is ‘XC Portal’? Is the the term used for the standard portal? If so, the update notes indicate that there is now an xmltv epg option for the portal. Does this mean you can add a different epg xml source file? If that too is correct, where do you enter the url for the epg file? I see where you can add it for the m3u playlist option but not for the main portal info.
Thx!
XC Portal is the XtremeCodes portal
I do not know if it applies to nfps/rocket servers thou.
But the XC portal is not there on this T1 Plus... It may have been just for the T2 and the Z7+ models... but I have not seen this personally.
epg entry is thru Playlist portal only, as far as I can see :eek:
New update was released the other day.
Current Firmware version V2.8.13
DOL2 App version V1.09.43 - r1797
Additional patches made to 'Stuck-in-Standby' issue.
Fixed app crash issue with certain portals.
Improved appearance of VOD subtitles when only one subtitle is present.
Fixed 'Can't Record Stream' issue.
Delayed auto-shutdown until in-progress recording is completed.
Remember subtitles preferences per channel.
General bug fixes and performance improvements.
Improved Lithuanian translation.
Please, not meaning to be a smart xxx or anything, but are they working on the EPG issue? I sincerely hope they are. Off by 4 hours makes my family crazy. Adjusting time zone only works for some channels and not others...
Please, not looking to hijack this thread but only trying to find out if the coders are working on it.
