https://www.upload.ee/image/14548980...6.18.29_PM.png
Xristmas at the corner
Gotta start that letter
E5 and B5 available for pre order :)
Code:https://buzztvglobal.com
Looks like more great boxes from BUZZTV.
I would like to figure out what box is best for me. I have a few Buzzes and as great as they are I can never figure out how to use them to there fullest. I am so lame.
How to figure out what I really need. is my question.
That would Depend on just what it is You exactly Want to Do...!!! Wouldn't it...?!?
Ryu recently posted another great chart. It shows the things you may want to know about the series 5 BuzzTV models:)
http://iptvtalk.net/showthread.php?4...OMPARISON-LIST
And another one in the Essentials forum
http://iptvtalk.net/showthread.php?4...omparison-look
For the 4000 series models, we'd need to look at the specs.
Some basic and important specs to look at :
- Output Resolution - is it 4K compatible, or does one need 4k
- RAM and Storage - the more the better but less works fine too just for IPTV . But for recording, or just for fast responsive machine, more is better.
- Android OS version - newest is the Android 11, while this is not too important just for your basic iptv services, it can become important with the many apps available today.
- DDR - this function has to do with how the device puts good use to the RAM and or memory. DDR is okay while DDR4 is better
- Remote Control Unit (RCU) - Bluetooth or IR or other such as the backlight or the air mouse RCU
- USB ports - you want at minimum two , with one being the newest 3.0 version. Three ports would be ideal as you can never have too many.
- Micro SD Card port - need one of these ports is a must.
- Supported video and audio decoder and formats are important too, but for most part they all are about the same (more or less).
- Widevine version could be important too, depending on the device and what it's usage is. Don't worry about this thou if it's not seen in the specs.
