** New Releases ***
repository.kens13-1.0.0
context.IPTVXtra.mediainfo-1.0.0
plugin.video.IPTVXtra-2.2.2
*Small changes in IPTVXtra v.2.2.2
- Multiple Channel Categories Added (HD, SD, Eng -English, Esp -Spanish)
Example: Select Eng will omit all Spanish & Internationals
***Note: To update your Playlist with any new Channels or Features such as this, you must reload the PVR data by Clicking VOD or IPTV to get a list, then Select Auto Setting - PVR
*Release IPTVXtra Media Info v.1.0.0
Will take your Selection from a list and get Metadata information from tmdb and other sources, and Display it for you.
You can get the Summary description of the item, the cast bio. etc, and play movie Trailers and other features.
- Adds a context Menu Item that can be used from VOD listings, EPG /Channel Guide, and the Favorites List.
https://www.mediafire.com/convkey/7a...6nv27yj54g.jpg
https://www.mediafire.com/convkey/2d...q0l0jzob4g.jpg
https://www.mediafire.com/convkey/b1...aw975xwt4g.jpg
*Release repository.kens13 v.1.0.0
By installing the Repository, you can Install or Update your existing Addons.
Any changes will automatically get updated to your system upon startup.
Download the Repository zip file from the link below.
http://www.mediafire.com/file/jg045rogrocuxt4/repository.Kens13-1.0.0.zip/file
Open KODI and go to System Settings/ Add-ons/ Install from Zip.
Browse to the location of the downloaded zip file (repository.kens13-1.0.0.zip) and click to install.
Go back to System Settings/ Add-ons/ Install from Repository.
Scroll down to Kens Kodi Repository and click to open selection directory.
Click Video Add-ons/ - (IPTVXtra) to Update your existing, or Install initial, version of IPTVXtra Video Add-on.
Click Context Menus/ - (Media Info) to Install the IPTVXtra Media Info Add-on.
* A number of dependency plugins will load, so wait until it says "Media Info Add-on installed".
** I forgot to include a KODI Reboot routine, so you have to close and re-open KODI, to load the context menu items, in the System.
Other Items and Extras will be added to the Repo Soon.
Any problems, ...you know where to find me!
Enjoy.
