new update appeared
2015/04/08
VER=1.48
-fix HD channels lag
-fix audio/video sync
new update appeared
2015/04/08
VER=1.48
just checked, no update for the TVOnline yet...says I'm current..
I don't recall how to see the current version with the Online model.
With the Vixo1, you see it in small print at top right corner of the TVOnline APP menu screen, the same screen where it shows the VOD and LiveTV and Settings options.
Check in Main menu , could be in small print there in one corner, or in Settings maybe. The Vixo1 doesn't show it in settings.
New version is 1.48
you don't get to see the version in the tvonline model...at least I haven't found a way to see it..I just checked for new update, they may be later on this model..
a reboot may bring the update up, if you haven't yet.
Just shutting the power off with remote won't do it, gotta pull the power connection on this Vixo1
that did it...thanks...
AVOV and Mag both stay on top of things very well, I like the quick responses...
Thanks crazed did the update on the Online model will look at avov later, did see the data usage in kbps is active again and the 5 TSN channels use about double of most other channels, the VEVO music 270-2 use slightly more and is indicative of quality resolution.
came up here as soon as i turned box on.
Yeh .. Ver= shows at the top right of TVOnline initial menu along with the time and MAC # on the VIX01. When the app starts if there's an update it asks to install.
