New IPTV/Kodi box.
https://www.allaccessandroid.com/product-page/global-media-box-4k
Works very well and easy to set up and use.
Fully supported with OTA updates.
PVR Feature. Record the IPTV stream media :cool:
Loaded with Kodi 17.3
Android 5.1
https://image.ibb.co/bvMbGa/gmb.jpg
Picture of remote,
https://image.ibb.co/cm9Kma/globalremote.jpg
Menu screen is cool. Carousel menu screen
My TV
Kodi
All Apps
Google Play
Cloud
Browser
You Tube
Settings
Sample,
https://image.ibb.co/nAM42F/gmbmenu.jpg
IPTV Specification:
API ·JS Linux API Network (portal) protocol support.
streaming ·RTSP, HTTP, HLS, RTMP, MMS, RTP, UDP, IGMP,
PVR .Record the IPTV stream media,
Vod ·RTSP, HTTP, HLS, RTMP, MMS, RTP, UDP, IGMP,
Remote Control ·Play,Stop,Fast forward, fast rewind,Forward, backward,Flying squirrels,learning,Etc.
interface:
Port
DC-5V 2000ma( VDE,Xterra,BS)
USB USB*2 HOST function
WIFI Outer wifi Antenna
bluetooth
AV Mini CVBS-1,Audio-L/R
S/PDIF Digital Audio
RJ-45 100M Ethernet
HDTV HDMI
Configuration Specification:
CPU .Quad Cortex-A53- 64bit
GPU Six-core High performance GPU Mali450-MP4
Memory
·32-bit DDR3 (2GB)
·Flash: EMMC 8GB
Wi-Fi · Dual-band wifi, 2.4 G/ 5 G/BT4.0, wifi t1r rate reached 72.2 1 Mbps.WiFi antenna outer,
Network .RJ45 Interface 10M/100M adaptive
Media Decoder:
Video
Decoder:
.H.265 decoding up to 4K×2K/30fps HEVC technology ,
.H.264 HP/L5.1 up to 4K×2K/30fps HEVC technology,
SVC, MVC, VC-1/WMV, AVS, WebM, RMVB, MPEG1/2/4, MJPEG, H.263, DivX 3/4/5, Xvid,
Real Video, VP6/8
Format:
MKV, TS, M2TS, MOV, MP4, RM, RMVB, AVI, MPG, MPEG, DAT, VOB, FLV etc.
Video modes:3840*2160,1080i, 1080p, 720p, 576p, 480?, PAL, NTSC.
Audio
Decoder:
MPEG 1/2/2.5, Audio Layer 1/2/3, WMA Version 4/4.1/7/8/9, WMA Pro, LPCM, PCM, Vorbis, Flac, ALAC,
APE, AAC-LC/HEAAC/HE-AAC v2, Dolby Digital plus (optional), DTS (optional),
Format:
MP3, WMA, WAV, OGG, M4A, MP4, AAC, APE, FLAC, ALAC, MPEG, MP1, MP2, MPA etc.
System
·OS:Android ,Linux system(Optional)
·Compatible with 3D. Microsoft Windows 8
