Hi As Capt said that take it back to the seller you bought it from, you should not have problem if he is an authorized dealer. There is no fix for the two solid green lights. Thanks
Yes, there is no known fix for the issue of the two hard green lights on the Dreamlink T1 Plus.
The unit was shipped back to the seller, and as there are not many Dreamlink T1 Plus around now, it was replaced by the Dreamlink T2 with a small additional cost.
Hi, did anyone find a fix for these boxes. Got same problem here. Thanks.
This is probably not related but mine would never go past the blinking red and green light.
After power cycling the button on the back repeatedly, I finally got it to get one solid green light but still nothing on the screen.
Trying the remote channel up/down, volume ect to reach a boot screen and nothing. After getting frustrated and pushing a whole bunch of buttons like crazy. The menu screen finally popped up.
Whether or not there is any logic to what happened? Just by dumb luck mine is working again now.
My T1+ just got both green lights on also....tried to turn off ect….no luck....but put the file on a sd stick plugged it in held up ch on remote and it came back.....didn't have to load anything...
Back to normal now.... Im not sure if the file did it or it just booted by itself.......lol....working fine now..
What file did you put on usb stick, trying to get mine up and running.
I did this to recover
http://iptvtalk.net/showthread.php?3...-for-T2-and-Z7
Use the URL to get the file,,, it puts the box in a reset mode,then boots up.
i too run into this problem with a T1 plus,i saw the tread about the recovery facinit but it said that only works on T2 and formuler,but i figured what the hell it's already not working so i got it here: http://www.mediafire.com/folder/f1maxx7vqaaqn/Recovery
here's what i did:
i extracted files,then put it on a flas drive,put it on stb in usb port and connected it and it came back!!!
it worked for me but use it at your own risk! it should work for you too!!! good luck!!!
thnx yup, it was confirmed some time ago that the T1 Plus is also compatible with that recovery method.
We just fixed the thread so it shows that:)
Dreamlink T1Plus, Dreamlink T2 models and Formuler models.
There is also another recovery file which works with Formulers and Dreamlinks
It is shown at the bottom in Method 3 thru the linked thread posted below and is confirmed to work with Dreamlinks and Formulers, (same as the facinit version).
http://iptvtalk.net/showthread.php?3...905#post246905
