T1 Plus S/W pushed update
-Old S/W
S/W Version v2.8.0
S/W Revision r12700
01-24-2018
-New S/W
S/W Version v2.8.10
S/W Revision r13952
04-05-2018
You should see this new Software automatically pushed to your T1 Plus, thru pop-up menu screen when you connect online.
This will come with a new 'Upgrade Menu' option, which will be found in the Settings menus (right beside the Andriod menu icon).
There is still in beta the IPTV Version of the update and you will not see that yet.
After the S/W Version v2.8.10 has been successfully loaded, open the new Upgrade menu and you will see the Current Firmware , which now should be v2.8.10.
And also should see the Current IPTV version and it should show as v1.9.7
The new IPTV Version has not been pushed or publically released yet.
The new IPTV Version will be a higher number.
We should see this new IPTV Version released soon to follow :)
S/W Version v2.8.0
S/W Revision r12700
01-24-2018
S/W Version v2.8.10
S/W Revision r13952
04-05-2018
IPTV Version
v1.9.7
IPTV Version (Beta testing)
v1.9.15
New IPTV Upgrade
April 10, 2018
IPTV Version : v1.9.17
with Current S/W Version : v2.8.10
After correct updating, in the Upgrade menu it should show as...
Current Firmware Version : v2.8.10
Current IPTV Version : v1.9.17
Newest push today (April 11, 2018)
S/W Version v2.8.12
IPTV Version v1.9.17
Newest push today (April 25, 2018)
S/W Version v2.8.13
IPTV Version v1.9.24
