crazed 8.4. Thank you so very much for you help. You are great I really appreciate you and your help. I sure hope that all is well MArley and the family, my prayers go out to them.
I loaded catmouse. I get a lot of buffering. I use wifi 5G had a good signal. Would an wireline adapter 100Mpbs be better or is it to slow for HD?
Also, it give a choice of using 'youtube or Google". do you have a preference?
cat mouse is a very good app it run smooth you have to change the video player from the default app player and choose mx player for the video player in the app setting but make sure you have mx player install on the box once you choose mx player for the video player in the settings its smooth sailing.
Here are some good apps I use.........................................Have used all these Apps on Buzz 3000 ...4000 and 4500 boxes
CatMouse
TeaTvCode:https://www.djjubeemedia.appboxes.co/Apks/Movie/CatMouse-v2.3%5BAd-Free%5D.apk
TyphoonTvCode:https://www.djjubeemedia.appboxes.co/Apks/Movie/TeaTV-v10.0.3r%5BAd-Free%5D.apk
VivaTvCode:https://www.djjubeemedia.appboxes.co/Apks/Movie/Typhoon-TV-v2.2.8.2%5BAd-Free-Mod%5D.apk
FreeFlix-HQCode:https://www.djjubeemedia.appboxes.co/Apks/Movie/VivaTV-v1.1.9v%5BAd-Free%5D.apk
Code:https://www.djjubeemedia.appboxes.co/Apks/Movie/FreeFlix-HQ-v4.3.0%5BAd-Free%5D.apk
try install it from the play store or put it on a flash drive and install it into the box.
Best way to install APK's on a Buzztv Box..is to put the apk's on a flash drive and in the box open up "file browser" .......install apk's
yup thats how i do it and have many on my stick and you could do file manger and use codes too must have hundreds that way i can use and this is hell of box to use with all that space
I had xrs4000 which i moved to the bedroom and bought xrs4500. This box is very fast and i find the picture quality way better than 4000. And love the BT remote, very responsive.
