It was pushed and replaced my old stalker client. Works great. Thank you for not leaving us kodi users hanging. I never had much luck with the pvr client.
Working great for me, thanks
This is working great for me. Big Thanks Dara!
Thanks - works awesome - I was never really a fan of the PVR Client. I use a FireTV Stick and always found the guide to be a bit heavy on memory. On a future update can you see if it is possible to disable the other portals if they are not used. I ran into the situation where it would always fail authenticating - it would still work but it would authenticate each portal - I ended up putting in my donation for all 3 portals on the login and password so it would stop giving me the error.
Dara, you saved a lot on people who could not use the other PVR S.Clients and Stalker"s Clients.. Works great..:o Thank you for all the time and effort you do to make things work for others...."You are the best" .. andkaal;)
