IPTVXtra II and KODI v19 Matrix *Warning*
IPTVXtra2 will not work with Kodi 19.
Since it is now released as a Stable Version, if you have Version Check enabled and set to Update Automatically, when you start Kodi, it will install the new version, and you will no longer be able to use any IPTVXtra functions (VOD, Playlist updates etc.), though you can still have TV with the existing m3u playlist.
If you want to avoid this, disconnect internet, open Kodi, go to System settings/Addons/my addons/Services -version Check, and disable.
Shutdown Kodi, connect internet and restart Kodi.
*Update*
Will be updating the addon, but may take up to a month, to incorporate all the new features available with Kodi v19.
* Will try to release a temporary fix before that.
/Shooty
